jeffantastic
Overnight Sensation WWTWW CC Build
Mon Mar 25, 2013 1:05 pm
This is my build log for my first-ever speaker build. I've chosen the Overnight Sensation Centre Channel design by Paul Carmody and ordered from Meniscus. I decided on the OS CC because I have a decent Sony HTIB receiver but have been very disappointed in the supplied speakers. I mostly use the system for watching movies and have found the dialog audio the worst. I eventually intend on doing a complete 5.1 system of Overnight Sensations but am starting with the centre channel to get clearer dialog and cus it's only one speaker so I assume that it will take less time.
Being new to DIY speaker building, I began by surfing the net for information and after a couple weeks I kept coming back to Paul's website. https://sites.google.com/site/undefinition/diy His site is very helpful for beginners and was immediately interested in the Overnight Sensation. I liked that they were inexpensive, had a number of different options (MT/MTM) and the copper-coloured drivers looked great. When I eventually determined that I wanted to do a centre channel, I happened upon this page kind of hidden on his site https://sites.google.com/site/undefinition/updates/overnightsensationcenterchannelbipolewhatwhen And that led me to Meniscus. I ordered the parts March 13, they arrived March 22, and I began the build on the 23. I'll get photos and a log up as soon as I can.
Jeffrey
jeffantastic
Re: Overnight Sensation WWTWW CC Build
Tue Mar 26, 2013 10:39 am
As posted above, I received the kit last Friday and was very pleased with how quickly it arrived and what I found in the box.
The kit unboxed
jeffantastic
Tue Mar 26, 2013 10:49 am
I assembled the crossovers on Saturday. I had spent the week prior designing possible layouts while I was waiting for the package to arrive. Since I wasn't sure how big the components were my attempts were just exercises in deciphering schematics. My guess was that I was going to want to split board into two parts. So I wasn't surprised when the kit came with instruction on how to optionally layout the board for for two boards. Meniscus even supplied two choices for one of the resistors! The woofer openings are going to be very small, so compacting the layout was important. I mostly followed the suggested layouts. Although the two boards will be separated by more than 20cm, I still wanted to flip the orientation of one of the air core inductors to be safe and I used the saved space to use the larger 10W resistor.
My completed crossovers (tweeter on left 1.5 woofer on right) with suggested layout below.
jeffantastic
Tue Mar 26, 2013 10:58 am
After putting together the crossovers, I was excited to get a first listen. I temporarily connected all the wires to the drivers and connected the centre channel output from my receiver. The made noise, which was a relief. I also could detect that the sounds appeared to be appropriate filtering to the correct drivers. In this MMTMM design, the outer two woofers are have an additional filter so they play only a lower potion of the range handled by the inner woofers. Without the cabinet, they didn't sound great of course, but they already sound much better than my existing centre channel. Ha! I only tested using some electronic dance music but when I switched back to my old centre channel my wife described the difference as the old one sounding static-y. I can't wait to get these in a cabinet.
Initial crossover test
jeffantastic
Sat Apr 20, 2013 11:03 pm
Day two-April 20, 2013
Began the cabinet build. Cut for 1/2" MDF per the instructions. I used a circular saw with the Kreg rip guide. It went pretty quick. I decided to use glue and screws for the butt joints on the sides top and bottom, but am only gluing the face on for aesthetic reasons. I also rabbeted the two side pieces on the back so that the back piece will have something to rest against when I insert it. I've routed out the holes and chamfered the back. I countersunk the holes and also rounded the entire face piece. I'm pretty happy with the results.
osd1
Mon Apr 22, 2013 9:12 pm
keep the pics coming. looks good so far. how do you plan on finishing it?
jeffantastic
Tue Apr 23, 2013 1:57 pm
Yesterday, I painted the cabinet using Canyon Black spray paint with a satin finish. It looked pretty good. I'll post pics tonight hopefully.
jeffantastic
Tue Apr 23, 2013 2:01 pm
Quick question. Most builds I've seen finish the cabinet first, then put the xo's in through the driver openings and mount the drivers last. Since the driver openings are so small on this project, I'm planning on mounting the drivers first with the back panel open, soldering everything together, then putting on the back panel last. Any issues with this procedure?
jeffantastic
Wed Apr 24, 2013 12:07 am
After about three or four coats of paint, the cabinet looked like this:
It's not super smooth but I'm pretty happy with it. I glued the crossovers in with Gorilla glue, ran wires through the driver openings and soldered on the drivers then screwed them in. Once everything was in place, it looked like this:
I had a lot of trouble soldering the copper wires. Is there a trick I need to learn? Solid metal seems to solder quickly and easily but not the twisted copper.
I sure do love the look of this design.
jeffantastic
Wed Apr 24, 2013 12:13 am
Before closing the back panel, I wanted to give it a listen to make sure I got it all right. Listened to Moby Play. Even with the back panel open it sounded nice. Better with the back on though. And once I got some stuffing in behind the woofers it sounded great. I ended up using all the stuffing that was supplied with the kit. Satisfied, I glued the back on.
