jmarshall
Finalists - Where to mount crossovers?
Fri Jan 02, 2015 9:29 am
I am building Finalist using the parts kit from Meniscus. The kit includes three separate crossover boards (for woofer, mid and tweeter). Where should these be mounted? If I understand correctly, the majority of the inside cabinet surfaces will be covered with foam.
Re: Finalists - Where to mount crossovers?
Fri Jan 02, 2015 11:35 am
You can mount the crossovers most anywhere that is convenient. You can cover them up with the foam afterword. You might need to slit the foam for any hookup wire to pass through.
Users browsing this forum: No registered users and 4 guests
