Blues TM first ever build!
pleppink
Post by pleppink » Tue May 19, 2015 10:56 am
Hey guys its my first attempt at a speaker build. I am building the blues TM kit and I will definitely need help along the way!
Re: Blues TM first ever build!
Post by mattsk8 » Wed May 20, 2015 2:59 pm
Feel free to ask any questions, I'll be glad to answer. Good choice, glad you're building them. Can't wait to hear how you like them!! Are you building the towers or the monitor versions?
pleppink
Post by pleppink » Sat May 30, 2015 12:46 pm
I believe I am just making the monitors. Those are the ones with just two drivers correct?
Ok I am going to start by working on the cabinets (crossovers next weekend.) I was wondering about the inner and outer cuts for the drivers. Is the surface between the cuts beveled or just straight?
Also there is a picture of a finished blues TM build on this forum that has rounded sides but as far as I can tell the instructions are for rectangular cabinets. Is that correct?
It says you are supposed to measure the drivers for the speaker cutouts. Where are you supposed to measure them?
Also it says for the inner tweeter cut out you need to save room for "ears for terminals" what does that mean?
The instructions give measurements for the "vent" is that the white rectangle in the upper right hand corner of the of the diagram for the side of the cabinet?
Is the back of the speaker cabinet just a solid piece of 3/4'' MDF? or should there be a cutout for some cords?
Will this cabinet need bracing? Is there any type of bracing you would recommend that wouldn't be too difficult for a novice builder?
Thanks for your help and sorry about all the questions, I just really want to make sure I am doing everything correctly and also learning about what I am doing.
I am not super familiar with woodworking terminology so hopefully you can understand what I am trying to say.
Thanks a lot,
Patrick
pleppink
Post by pleppink » Sat May 30, 2015 2:42 pm
Also do you use a router or a drill press to make the flush mount rings?
Post by mattsk8 » Wed Jun 03, 2015 8:55 pm
pleppink wrote:I believe I am just making the monitors. Those are the ones with just two drivers correct?
1. Ok I am going to start by working on the cabinets (crossovers next weekend.) I was wondering about the inner and outer cuts for the drivers. Is the surface between the cuts beveled or just straight?
2. Also there is a picture of a finished blues TM build on this forum that has rounded sides but as far as I can tell the instructions are for rectangular cabinets. Is that correct?
3. It says you are supposed to measure the drivers for the speaker cutouts. Where are you supposed to measure them?
4. Also it says for the inner tweeter cut out you need to save room for "ears for terminals" what does that mean?
5. The instructions give measurements for the "vent" is that the white rectangle in the upper right hand corner of the of the diagram for the side of the cabinet?
6. Is the back of the speaker cabinet just a solid piece of 3/4'' MDF? or should there be a cutout for some cords?
7. Will this cabinet need bracing? Is there any type of bracing you would recommend that wouldn't be too difficult for a novice builder?
Thanks a lot,
Patrick
Congrats!! I hope you have fun with this build and enjoy the end results 8-) . Are you replacing something you're currently using?
So regarding which one you're building, at least as far as I'm concerned a monitor is a bookshelf, and a floorstander is a tower speaker. So, a monitor could be either the TM (tweeter/mid) or a MTM (mid/tweeter/mid). So if I was telling someone what you were building, I would call it a "TM monitor". Some may disagree, but that's where I'm at :D . You could actually build this as a monitor or a floorstander if you wanted; the kits (the actual speakers and crossovers) are the same, the difference is the cabinet. Obviously from a woodworking perspective the monitor is easier to build.
1. As far as the "surface between the cuts", are you referring to the 1/4" space that's between the woofer and tweeter? If yes, this remains flat with the rest of the baffle.
2. These were designed with a 1/4 to 1/2" roundover in mind. It's not critical, I honestly doubt you'll hear a difference to be honest. But, I do think it looks better if the front baffle has a roundover on the edges of the sides of the front baffle. Top and bottom edges don't matter at all if they're square or rounded edges.
3. I'll also answer the question in your second post here as well. For cutting the driver holes, in my opinion the Jasper circle cutting jig is the easiest way to do it. If you don't have one of these, I'd go to Woodcraft and buy one, they're about $35 I think. Pricey for a round piece of plastic, but they work incredibly well. You'll also need a 1/4" router bit to use with the Jasper jig.
As far as measuring the drivers for the cutouts... Measure the diameter of the very outside edges of the speaker's frame, then measure the thickness of the frame where the screw holes are (usually 3/16" to 1/4" for the woofer, but these aren't exact because I don't have a woofer here that isn't mounted to measure for you). The tweeter's depth is 3/32", I did have one of those here.
As far as the outer diameter of the speakers go... for the woofer, 6 11/16" is going to be tight, 6 3/4" will give you room to breathe. For the tweeter 3 15/16" is pretty good. That's the extreme outside edge of the speaker's frame, and this will be the first hole you route for the recess.
The 3rd measurement is for the actual cutout for the speaker to sit in the cabinet. What I generally do is measure the mounting flange's width, multiply that x2, then subtract it from the diameter of the speaker. For example, if the woofer's flange measured 7/16", I would subtract 7/8" from the 6 3/4" woofer diameter, and make the hole 5 7/8" (not saying 5 7/8" is what to use, you'll have to measure yours because I don't remember exactly what the woofers were.
4. Cutting "ears for the terminals"... Once you get the kit (or maybe you already have it) you'll see that the terminals for connecting the wires to the speakers are on the outside edge of the magnet. So when you cut your first hole for the recess, then cut the actual hole for the tweeter to fit in the cabinet, you'll find that the terminals are in the way of allowing to let the tweeter fit. You need to cut little spots out for these terminals to fit in. To do this I loosely place the tweeter in the hole I made, then mark where I need to cut out for the terminals with a pen or pencil. Then I carefully cut these out with the 1/4" router bit I used to route the other holes.
5. The vent (or port) is a black plastic 2" round tube that would come with the kit. I do my vents the same way I mount the speakers, so once the holes are all cut the vent is flush with the back baffle of the cabinet. I mount the vent in the rear baffle behind the tweeter.
6. The back of the cabinet is a solid piece of MDF, yes. But so is the front, the top and bottom, and the sides. The back of the cabinet will have the vent (or port) as well as the positive and negative connecting terminals mounted in it.
7. Bracing isn't super critical on a cabinet this small, but if I was building it I would put a "window brace" right in the middle, horizontally. You'll basically measure the inside of the cabinet's width and depth, then make the brace that size. Here's a picture of the window style braces in my Blues MTM tower speakers. Basically you'll put one of these braces right in the middle. If you do this, when you route out for your woofer, you'll see the brace runs right through your cut out and most router bits don't go that deep. I cut the rest of the brace with a jig saw after I router all the holes for the speaker (if this doesn't make sense, it will after you lay the cabinet out and start cutting).
Looking at that^^ pic, you can see the hole for the port cut near the bottom. That's where the port goes in the floorstander, for your monitors that hole will be smaller, and towards the top of the cabinet right behind the tweeter.
Here's a picture of the finished speaker, just so you don't have to go to more than one place for info.
Have fun, and I really look forward to pics of the build, as well as how you like the way they sound 8-)
pleppink
Post by pleppink » Sat Jun 06, 2015 10:41 am
Awesome thanks so much. My one last question is as far as I can tell the plans I have are for a perfectly rectangular monitor, not one that curves inward from front to back like in the picture. Is that the difference between the tower and monitor version? I think seeing as this is my first build I am going to do the monitor version because I am not super confident with my woodworking yet.
I have mainly been working on the crossover and finding the tools and equipment to make the cabinets so it is not too late for me to adjust.
Thanks again and sorry for all the questions. I am just really enjoying learning about this.
Patrick
pleppink
Post by pleppink » Sat Jun 06, 2015 1:13 pm
Maybe you answered that one number 2, but I guess I am not sure what you meant. Would it be fine for a beginner to use straight sides instead of the rounded sides? Or will there be a significant loss of sound quality?
Post by mattsk8 » Mon Jun 08, 2015 10:06 am
Sorry, was out of town last weekend. The curved cabinet is also a monitor (AKA, bookshelf speaker). All that is, is an aesthetically different way to build the cabinet, you could build yours either way. Obviously if you're not overly experienced in woodworking, I highly recommend avoiding the curved cabinet build and stick with the straight, rectangular cabinet.
pleppink
Post by pleppink » Wed Jun 10, 2015 9:06 pm
Finally do you have a suggestion for what amplifier I should get to go with it?
I am hoping I can find something in the $200 range.
Post by mattsk8 » Thu Jun 11, 2015 10:54 am
By "amplifier", do you already have a preamp? Or is this the beginning stages of your entire stereo? If you don't have a preamp and your budget is $200, I recommend finding a used stereo receiver on eBay or Craigslist. As far as a specific model, it would depend on your intentions. Do you want home theater? If so, you'll need to build 5 of these speakers. I really can't answer the "which amp" question without a LOT more details about how you'd like to use your speakers. Just music? If yes, with a $200 budget you'll have to look fairly hard but I definitely think there are options in the used market. For something that'll drive a 4 ohm pair of speakers, I don't think there is anything available new in that price range.
