[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5312: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
Retrofit Klipsch LCR - Meniscus Audio Forum
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
mastercraft1990
Sat Jan 02, 2016 4:09 pm
I have a set of RF35 8" towers and RC35 6.5 center channel, all horn loaded that I want to refit with some higher end drivers. I can't seem to sell them so I can build a set of MTM's for LCR and I'm not looking forward to battling with the wife about the perfectly "good" speakers I already have so why not use the boxes I already have. I would revise the horn area to accept a dome tweeter and as of now they are wide open except for a 4" x 2 1/2" port on the back. I planned on getting with Chad for advise on drivers and crossovers and also plan on ending up with a 4 ohm setup to be driven with a 330 watt Emovita 3 channel amp. Any thoughts? Towers are 40" tall x 9" wide x 14" deep and center is 23" x 8" x 11"
Post Reply [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
