Version 1.501 - New driver filter UI and user requested UI changes
Sat Jul 09, 2016 12:22 pm
The driver filter UI has been changed to use two controls instead of one. This separates selection of crossover type and slope.
Other changes to the UI cover several requests made in the forum here and elsewhere. The window size can now be increased for the problem found in Windows 10 that caused scroll bars to appear and require constant change during use. A window close dialog opens on exit so that it can't be accidentally closed. The System window has an option to keep it on top of other windows. Other changes are listed at my web site.
Re: Version release v1.510 - Polar response improvements, UI changes and small bug fixes
Sat Mar 18, 2017 12:25 pm
v1.510 changes:
Has a bug fix for 3-ways with a midrange having higher order highpass that truncated the summed response if the midrange low end went down to 0db.
The polar response section is improved to more accurately reflect the off-axis response. Please read the Help provided carefully. It's important to follow the instructions if you direct measurement files that are post-processed to be minimum-phase. The polar section will need to be filled in appropriately to get the correct on-axis response from measurements.
If you use direct measurements not post-processed (includes excess-phase), then the polar response section should be left alone. If you enable the polar section, both the off-axis will not be accurate, but more importantly, the on-axis will not be correct, either. Excess-phase files are good for one point in space only, the measurement point.
If you use SPL traced files (minimum-phase) , the Reference Angles should be left at 0, since traced files usually are derived from individual driver on-axis response curves, but all other polar  setup values should be entered and used.
Details are in the Help of the program and at the WinPCD web site, but to point it out here, the driver diameters are never required, but help to provide more a better indication of the off-axis. If they are left at zero, the off-axis only shows the crossover effects.
Version release v1.513 (UI responsiveness), 5 Jan 2018
Fri Jan 05, 2018 10:27 pm
Prior to this release the user interface locked up when the polar calculations were being made. No windows could be opened or moved, even the polar window would accept no user input. There was a single thread.
With this release the user can now open, move or close windows to include the polar plot window. Controls that affect the calculations cannot be changed, however, because this would interfere with the polar plot calculations. The polar plot window can be closed prematurely and the settings will all reset to what they were before calling the polar plot.
While coding these changes I noticed that there was some error in the off-axis response. The farther off-axis the mic angle, the more error occurred in the calculations. That has been corrected and I think that the off-axis calculations are now accurate. Keep in mind, however, that the off-axis has two components, the change in delay from each driver due to different distance and the change in each driver due to  the off-axis response change. The latter is a calculated change based on the basic assumption of a flat radiator. It's not accurate (and possibly worse than reality), but it provides a basic idea of the change with angle.
Users browsing this forum: No registered users and 2 guests
