[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5312: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
Series RL (Lp Filter and Resistor - Meniscus Audio Forum
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Jeff S.
Sun Jun 21, 2015 5:35 am
Dave, I was working on a crossover and notice that in the Series RL before crossover circuit doesn't allow me to but in the resistor value. Any chance you could look into this?
Re: Series RL (Lp Filter and Resistor (edited)
Sun Jun 21, 2015 9:09 am
Hi Jeff,
I was puzzled when I first read this because I've had the resistors in the circuits from early on. (clip)
Edit:
Looking back at this, I was thinking in terms of adding a series resistor in the schematic. However, the inductor has a DCR that is part of the element. I have not added a series resistor in the circuit because it's generally better to have the lowest impedance possible for most inductors. If you need to add resistance for some reason, increase the DCR value as appropriate. When compete, subtract that inductor DCR from the total and you'll have the resistance value needed for a resistor to add in series with the inductor when you construct the circuit.
Post Reply [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
