Impossible to download ?
Questions and discussion about the Windows version of PCD
antoinelet
Post by antoinelet » Sun Dec 20, 2015 1:38 pm
Hi everyone !
I have built a few loudspeaker boxes in the past and I have always been using simple crossover from parts-express. However, I think it is time I start making my own crossovers. WinPCD seems to be the perfect software for that :) Unfortunately, I can't complete the installation : when I lunch setup.exe the wizard connects to internet and return the following error :
Impossible to download the application. Files are missing.
As I am speaking french this is a translation, but you get the idea. From the details of the problem it seems that the missing file should be there :
http://www.speakerdesign.net/WinPCD/ins ... pplication
I am trying to install version 1.500. If any of you have ever encountered this problem could you please share your solution if you have solved it ?
Thank you, any help is greatly appreciated ! :)
Antoine
Re: Impossible to download ?
Post by dlr » Sun Jan 24, 2016 10:15 pm
Given your second thread start above, I assume that this problem is solved? I've heard of others having a similar issue. I can't replicate it myself. Running the application directly (for others who may experience this problem), i.e. double click the application exe file should work. I think that the "install" is only required to download any .NET framework files if required, in this case, .NET 4.0.
dbeeman
Post by dbeeman » Sun Apr 03, 2016 11:03 pm
I get ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of F:\Program Files\winPCD\WinPCD.application resulted in exception. Following failure messages were detected:
+ Downloading http://www.speakerdesign.net/WinPCD/ins ... pplication did not succeed.
+ The remote server returned an error: (404) Not Found.
Post by dlr » Sat Jul 09, 2016 3:22 pm
Sorry to be so late replying. There have been a few instances of this and I don't know the reason. It's some odd thing related to the Click-Once installation. Installing a later version has at times worked (1.501 is now available). What you can also try and should work, if you already have a good version of .NET installed, is to extract the zip file to a folder of your choice (e.g. C:\WinPCD) and run the application directly. Make a shortcut to it on your desktop. It will be down in the directory structure in the folder with the version number.
