[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5312: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
my basics - Meniscus Audio Forum
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
tkroeker
my basics
Thu Sep 01, 2016 4:11 pm
I'm still having an issue with th ohm factor of designing.
The way I have figured out how to use this app so far is probably to basic but if I explain what I do maybe it will help me ask my question.
for this example,,, I import say two graphs of a woofer and tweeter both freq and imp. then I set it for Parallel two way, select orders high pass and low pass types. I continue changing values of capacitors, resistors and inductors until the pretty lines create somewhat of a nice flatish curve (lol).
I actually have a decent grasp on the app and what I am doing but the different ohm values of the tweeter vs woofer still throws me. If I have used my method so far and used an 8 ohm woofer and tweeter then did one with a 16 ohm tweeter,,,,,   does the app do something different? It seems like all I am doing is caring about the frequency curves but I know that a speaker with a different ohm value effects the crossover point
Post Reply [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
