mpryfogle
ZX Spectrum Build
Mon Apr 27, 2015 1:02 pm
I'm currently working through my ZX Spectrum build. I have the boxes built and am sketching out how I want to finish them. I ordered the kit from Meniscus but opted for Paul Carmody's 30 liter box design as opposed to the design from the instructions. A link to the gallery http://imgur.com/a/f1jIF
I am currently having issues as the speakers have 0 bass unless I crank the EQ from my receiver to full blast on the bass side. I've tested the woofers with a battery to verify that they are both in phase with each other and they do work. I have a large set of old Pioneer speakers in the room and the bass is normal sounding with those, while the ZXs currently have the bass response of a clock radio. This week I'll be working on debugging the bass issue. If anyone has suggestions, let me know.
** Update ** After playing for a bit, adding some polyfill and messing with the amp they have rounded out a bit, but are still very weak on the bass end. Much better than the clock radio, but not up to par for a decent set of bookshelf speakers, let alone small towers. If I turn the bass setting up to 8 (db?) then they sound much better.
Paul's design had an air core inductor for the woofer section while the kit came with an iron core inductor, I can't imagine this would make a huge difference but would it be advisable to change to the air core?
Paul Carmody
Re: ZX Spectrum Build
Tue Apr 28, 2015 2:16 pm
Do you have another amp you can test them with? They should have a healthy amount of bass. What size port are you using? Are there any air leaks (aside from the port)?
mpryfogle
Tue Apr 28, 2015 4:17 pm
I've tested with a lepai 2020 with the same initial result, I'll verify again tonight as that was before I had added much padding.
There doesn't seem to be any air leaks besides the port, which isn't sealed in yet. The box is constructed with overlapping rabbets and the back, sides, top and bottom were also culked before the front was glued in in an attempt to reduce any chance of air leaks. I will check on leakage around the Neo3 tweeters tonight and attempt to verify that there isn't any leakage in that area.
Any other tips would be greatly appreciated.
mpryfogle
Wed Apr 29, 2015 9:51 am
I set up the speakers on the Lepai amp with a similar result.
The port is the 2" port with the 3.5" tube from the Meniscus kit.
I set up a few of the other speakers I have at the house http://imgur.com/a/plAJ0 and would say that the ZX has weaker bass than any of the 3. The large 4 way Pioneers are beasts on bass. The smaller 3 way Yamahas had a similar bass extension to the ZX, maybe a touch more but not a large amount.
Stand up bass on a jazz albums sounds extremely thin and unrealistic and bass drum often sounds like just the beater on plastic as opposed to a satisfying bass drum sound without some major EQ changes on the low end. I noticed that your schematics had air core inductors for the woofer as opposed to the iron core supplied from Meniscus and didn't know if this would make much of a difference. Mark at Meniscus told me that the Neo3s I received had their backs off but he glued them back on as they were the last ones he had, but the Neos haven't seemed to have any issue from what I can tell.
Wed Apr 29, 2015 10:49 pm
That doesn't seem right to me at all. Is it possible the polarity on one tower is reversed internally?
The Iron-core should have less DCR, and in fact, increase the bass output.
mpryfogle
Thu Apr 30, 2015 9:22 am
I swapped the polarity of the tweeters, so positive to positive, ground to ground and it helped greatly. The tinniness is gone and bass instruments actually sound more like the actual instrument. The low end still seem to be lacking punch, but maybe I've just become too use to the monster pioneers with a hyped low end.
The sides of the box are lined with auralex pyramid foam and probably 5-6 oz per cabinet of polyfill. I've seen that that for a cabinet this size I should have closer to 9 oz per cabinet?
Thu Apr 30, 2015 11:22 am
I don't think that is better. This likely caused a suckout in the midrange that changed the tonality.
I'm wondering if the woofers are wired correctly, like just one might be out of phase.
I would double check it against the schematic...
mpryfogle
Thu Apr 30, 2015 11:04 pm
After work I pulled all the cables through the cabinet and verified where everything should go. I returned the tweeters to how they should be in the schematic and reassembled everything with no real improvement. Having the tweeters in the correct configuration does make the highs sound better and imaging is much improved, but the bass is still not there without cranking the EQ.
Running a sine sweep with an RTA on my iPhone (not the best for analyzing) and listening tests seem to show that while it is kind of audible below 60Hz, it's only barely and it doesn't start gaining enough amplitude until around 125 - 200Hz to really be heard in the mix. I've verified this by activating the EQ in iTunes and playing the same portions of several songs with the EQ flat and with 32 and 64Hz set to -12dB and was unable to tell which was which. Dropping the 125Hz was noticable.
Fri May 01, 2015 12:46 am
All the parts values in the schematic match and are in the correct positions?
If so- I don't know what the issue is.
mpryfogle
Fri May 01, 2015 10:37 am
Thanks for the recommendations. I know how annoying it can be trying to debug someone's issues remotely, especially when they don't have a great amount of knowledge in the area.
The resistor going to the tweeter is 8.2 Ohm instead of the specified 8 Ohm, but I doubt that would have much effect on the woofer. I have the ground line running to the cross over -> woofer -> tweeter as opposed to having the tweeter also wired directly to the crossover. I know for most electronic applications this isn't an issue (save sensitive op-amps) but seeing as completely unhooked and from just one channel running the bass still seems weak, I didn't believe this to be an issue.
I'm contemplating ordering better quality crossover parts than what came in the kit and rebuilding the entire crossovers with what Paul has spec'd on his page as well as sealing behind the tweeter to stop any sort of air escape through that port.
From everyone's review of this speaker, I believe it's got bass hidden inside there somewhere and I've probably messed something up, but it would be really nice to be able to find it.
Users browsing this forum: No registered users and 2 guests
