hockeymunch
Re: DIY Speaker Gallery - Show off your work
Fri Aug 28, 2015 9:22 am
Statement II build. Just finished yesterday. now to loosen them up and listen. I'm impressed already and it's only going to get better. Would I build these again? Absolutely. I learned a lot from the build and changed the cosmetics along the way... Hope yall like the look....
Statement II- fun build
hockeymunch
Fri Aug 28, 2015 9:30 am
Another look
Statement II -
Another look
More fun than one can have... Thanks Jim Holtz and Curt for a pretty awesome speaker design.!! I'd do it again and again... and again
Not to bad
Jim Holtz
Fri Aug 28, 2015 11:12 am
They look great! Excellent craftsmanship!
Enjoy the sound!
Tony Ray
Finalist centre
Sat Nov 28, 2015 5:45 pm
All the way from down under a Finalist centre.
Great upgrade from the Paradigm Centre 3.
Thanks Meniscus for the great service and Jim and Curt for the design.
I used 25mm MDF for the box and a 32mm solid wood baffle with a shellac finish. Very happy.
Jim Holtz
Mon Nov 30, 2015 11:04 am
Beautiful! The center is the foundation of a home theater system.
Enjoy!
knifejames
Tue Jan 26, 2016 4:05 am
These Satori drivers are great!
Im very happy with the Kairos. Thank You Jeff!
I dont like the card port.
the construction is Bamboo, white oak and some dark hardwood from a orangutang's habitat.
I cut the bamboo and oak on a cnc router so the drivers fit into the oak perfect.
the bamboo I profile cut then stacked to form the top and the bottom front radius.
the hardwood is used on the back(top) and the bottom pannel.
I have photos of the inside of the enclosure also.
The wall thickness of the enclosure varies but is at minimum 30mm all the wood used is super dense too.
djverne
Sun Apr 17, 2016 10:45 pm
Alpair 6m Mini
Alpair 6m Mini
djverne
Sun Apr 17, 2016 10:48 pm
djverne
Sun Apr 17, 2016 10:53 pm
Researcher
Mon May 16, 2016 2:05 pm
djverne wrote:
Beautiful veneer...what is it?
I also like your tube amp, which model is it?
Cheers :)
Users browsing this forum: Yahoo [Bot] and 1 guest
