Finalists - Where to mount crossovers?
jmarshall
Post by jmarshall » Fri Jan 02, 2015 9:29 am
I am building Finalist using the parts kit from Meniscus. The kit includes three separate crossover boards (for woofer, mid and tweeter). Where should these be mounted? If I understand correctly, the majority of the inside cabinet surfaces will be covered with foam.
meniscus
Site Admin
Re: Finalists - Where to mount crossovers?
Post by meniscus » Fri Jan 02, 2015 11:35 am
You can mount the crossovers most anywhere that is convenient. You can cover them up with the foam afterword. You might need to slit the foam for any hookup wire to pass through.
