http://www.tymphany.com/wp-content/u...hure-Final.pdf
http://www.tymphany.com/peerless/tra...etail/?id=1134
What a beast!!
New Peerless STW350 15" on the horizon...
**InDIYana event website**: https://sites.google.com/site/indiyanaevent/home
Photobucket site: http://s18.photobucket.com/albums/b117/ ... h_speaker/
Re: New Peerless STW350 15" on the horizon...
I like how you can bolt to the back of the woofer from your brace.
Wow. They suggest a 160L box for vented use but according to the EBP (41) this is definitely for sealed box use. And the 'compact' sealed box is 80L!
Then again, even at 80W input (vented) you aren't even coming close to XMax above 16hz. It takes 250W (and about 108db) to reach Xmax and with their suggested port configuration, port noise won't be a problem either. That there really is a beast.
