Chamfering speaker holes
What do you usually do to chamfer the back of the speaker holes? Is there a specific bit you prefer to use?
Re: Chamfering speaker holes
Depends on the driver. If there is not much window for driver breathing in the basket of the driver, then I prefer a 1/2" R cove bit. If the magnet gets in the way of breathing in a thicker baffle, then maybe a cove plus 45* chamfer to finish it off.
For some drivers a 3/4" roundover is enough, and 8" drivers are more typically don't require the relief.
This is a 1/2" cove followed by 45* chamfer, and the driver was a 4.5" with very little basket breathing room:
This is a 1.5" baffle combined with limited breathing room. I used a 1/2" cove, then flush trimmed to the cove relief, and then rounded over the inner edge with a 3/4" radius.
This is just a cove bit between the screw-mounts as it's traditionally done:
Hope that hekps,
Hope that hekps,
**InDIYana event website**: https://sites.google.com/site/indiyanaevent/home
Photobucket site: http://s18.photobucket.com/albums/b117/ ... h_speaker/
Man! I wish I knew that before I assembled my first cabinet. This could be detailed or explained better in the drawings for the Mini-Statements I'm building right now. I'll have to find a way to add the relief bevels with the baffle installed. I'll probably use a trim router and free hand it.
Martin
Martin
A dremel would work w/ a carving bit for freehand removal, then fine tune w/ a file to smooth it out.martyv wrote:Man! I wish I knew that before I assembled my first cabinet. This could be detailed or explained better in the drawings for the Mini-Statements I'm building right now. I'll have to find a way to add the relief bevels with the baffle installed. I'll probably use a trim router and free hand it.
Martin
These are not cheap, but work well http://www.routerbitworld.com/Freud-85- ... 85-384.htm
We have one. We should rent it out
Yeah- I priced those Freuds when I went looking, and they are about $80 each. MLCS carries a 1/2" round-under bit in a 1/4" shaft for about $20. I haven't used it yet, but I have one. What I want is a cove-under!
Last year Woodcraft had one (or one like it) on sale for 50% off! Needless to say I scarfed it up in a heartbeat.
I'm not a great cabinet builder by any stretch of the imagination but they're good enough that the wife lets me bring them in the house.
I used to use 45 degree bits etc. and finally just started using a 3/4" round-over bit on the inner baffle to allow the drivers to breath. It works well and I've not had any issues with screws coming loose from lack of material to bite into.
HTH
HTH
