Swopes MTM
chambers13
Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 9:51 pm
My Swopes MTM build
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 9:53 pm
Cutting the recesses...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 9:56 pm
We have separation!
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:00 pm
Initial assembly
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:02 pm
More dry fitting...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:12 pm
Final glue up and sanding
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:13 pm
More sanding...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:16 pm
Applied finish...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:18 pm
5 coats hand rubbed Tung oil, 2 coats hand rubbed furniture wax...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:21 pm
Stands initial rough cuts...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:22 pm
Stands, assembly / primer
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:27 pm
Stands, finished.
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:28 pm
More stands...
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 10:30 pm
Stands and enclosures...hope to put the crossovers and drivers in this weekend!
chambers13
Re: Swopes MTM
Post by chambers13 » Tue Jan 07, 2014 11:34 pm
These are my first speaker builds, any suggestions / modifications or opinions would be welcome before I drop the drivers in. I'm pretty much going to use the fill included with the kit, as recommended. Also, with the forward facing ports, how critical will wall spacing be behind the enclosures? They will probably be going in a bedroom with limited space, and initially may be in corners a few inches away from the walls, I know it's not ideal, but how much influence will it have? Thanks for any help in advance!
