Overnight Sensation CC Woofer Placement
scarjacket
Post by scarjacket » Fri Sep 13, 2013 10:47 am
Hello,
First Post! Woot! I actually have a newb question... I recently decided to take a stab at DIY speakers and this OS Center Channel will be my first project, so be gentle...
I don't see from any of Paul's crossover drawings or from internet/forum searches, which woofers are supposed to be on the outside and which ones are next to the tweeter. And since I don't know enough about crossover design yet, I figured I'd ask the forum... Here's a pic with Red & Blue circles. Probably easiest if someone just says which is which.
OS Center Crossover - Woofer Locations.jpg (35.64 KiB) Viewed 17582 times
Any replies are appreciated!
Thanks!
ludespeedny
Re: Overnight Sensation CC Woofer Placement
Post by ludespeedny » Fri Sep 13, 2013 2:31 pm
Red should be outer. At least in my CC build it is working properly that way. Are you doing the split board crossover?
scarjacket
Post by scarjacket » Fri Sep 13, 2013 8:11 pm
Thanks for the quick reply!
I still haven't decided yet if I'll do the split board or not. When I first saw the kit, I didn't consider breaking it out into two boards, but when searching for other builds of this speaker, I've seen a couple places and I'm thinking that may be the way to go, since its such a tight fit, should the crossover ever need servicing.
Thanks again!
ludespeedny
Post by ludespeedny » Sat Sep 14, 2013 12:07 am
Here are some pics of my build so far: https://picasaweb.google.com/1023660837 ... directlink
You can see my crossovers to get an idea of what it would look like.
kevin007
Post by kevin007 » Wed Nov 13, 2013 12:54 pm
scarjacket wrote:Hello,
Thanks!
Paul has some good info on his site for this build: https://sites.google.com/site/undefinit ... lewhatwhen
I have also built this speaker from a Meniscus kit and it turned out quite well I think. Once you get it hooked up and dialed in you will love it.
Kevin
Shaken not stirred...
